I just recently got the following:
Asus P4b (i845) w/ 1 gig of pc133
Intel P4 1.7ghz
Adaptec 29160n
36g Atlas 10k2 & 36g 10k3
Intel Pro100b nic
Creative Audigy
I know the Audigy is not supported. I get a boot error when trying to install from the RH7.2 cd.
I read that there is support for the 845 chipset in 2.4.13-ac7 & 2.4.14 & 2.4.15 pre4 .
Which kernel should I use & how do I install when I cannot even boot the current rh7.2 install cd ?
Can I remove my boot scsi hd and put it in another computer (Asus Cubx mobo) ?
I could install w/ this cubx mobo then down load one of the newer kernels, compile it , then
move my hd back to the P4B (i845) system ??
Your help is greatly appreciated.
Regards,
Jose
Intel P4 1.7ghz
Adaptec 29160n
Intel Pro100b nic
Creative Audigy
Regards,
Jose
