- Oct 12, 2000
- 5
- 0
- 0
Guys i need urgent advice on this one...i have a CPU and I have not been able to decide on which 19" monitor to buy.My budget is around 300-320 Dollars ...I have narrowed my search down to two monitors...the NEC MS95 and the Samsung 955DF......the problem is I can find no review on the planet for the NEC MS95 monitor, but i feel 260 is a good deal for an NEC ( big name?) 19" 300 - 40$ Coupon = 260. Ive got a similiar deal for the Samsung 955DF( 270 after rebate) , but due to lack of information i cannot decide on which monitor to buy....the specs of both the systems are the following
NEC MS95 19" ,0.26 mm trio dot pitch
640 x 480 @ 60 to 160 Hz
800 x 600 @ 55 to 153 Hz
832 x 624 @ 55 to 144 Hz
1024 x 768 @ 55 to 120 Hz
1152 x 870 @ 55 to 105 Hz
1280 x 1024 @ 55 to 89 Hz
1600 x 1200 @ 55 to 76 Hz
Samsung Syncmaster 995DF (Dyna Flat)
19" (18" Viewable) 0.20mm dot pitch (horizontal)
1600 x 1200 @ 68Hz Maximum Resolution
Recommended Mode 1280 x 1024 / 75Hz
Supportable Refresh Rate Max 1600 x 1200 / 68Hz VESA
1600 x 1200 / 65Hz
1280 x 1024 / 60, 70, 75, 80Hz (80Hz max)
1024 x 768 / 87i, 60, 70, 75, 85Hz
800 x 600 / 56, 60, 72, 75, 85Hz
640 x 480 / 72, 75, 85Hz
Those are the specs.....i would be very thankful for any advice.....thanks!!!
1600 x 1200 / 65Hz
