Help Req. with NF7-S,XP 2100+
gagan512
Hi,
here's my system config:
Abit NF7-S nforce2 mobo
athlon xp 2100+
GEIL PC3200 (DDR400) : 2 x 256 MB (=512MB)
Radeon 9500 PRO
WD 80GB SE
Artec 16x DVD, Liteon 52x CDRW
420W PSU (Turbolink)
I bot the sys frm www.cyberpowerinc.com
i cant install ANY OS on it,, tried XP pro, 2000 pro, 98SE !!! always get the Blue Screen of Death !
various errors reported: Page fault, IRQ not less than equal, etc...
I've changed the CPU,RAM,MOBO already as i had the SAME problem with my old mobo : Leadtek Nforce2,Kingmax ddr400 RAM...
I've tested the 9500 pro and the HDD in other computers and they work fine.. Basically, i've singled out every single component and it works fine individuallly,, expect for in my system !!! always get BSOD !!! cant install any OS at all...
PLEASE PLEASE PLEASE help me out sum1... desperate !
any ideas ?
thanks...
have you tried running the system with the motherboard out of the case and resting on cardboard (or other non conductive surface)...could be a weird intermittent short from a standoff, or to the case.
have you tried another hard drive cable?
try it with the bare minimum connected (disconnect cd/dvd drives, etc)
how about the power supply, could it be unstable?
good luck
hi,
this is classic bad memory. even though you changed it, have you tried running memtest or docmemory, either can be run from a floppy.
docmemory
memtest
try and see if you get errors.
like ww said, be sure to check cables and swap them and try installing with the minimum. can you try installing with just 1 memory stick?
good luck
