My very computer illiterate father somehow managed to infect my poor computer with malware. I removed the trojan horses easily enough, but Spybot/ad-aware/hijack this keep on detecting 3 redirecting commands contained in my host file. I've removed the lines from my host file, deleted the contents of my windows/temp and temporary internet file folders and yet they keep on coming back. What else can I do?
This is what is put into my host file:
69.20.16.183 auto.search.msn.com
69.20.16.183 search.netscape.com
69.20.16.183 ieautosearch
127.0.0.1 www.igetnet.com
127.0.0.1 code.ignphrases.com
127.0.0.1 clear-search.com
127.0.0.1 r1.clrsch.com
127.0.0.1 sds.clrsch.com
127.0.0.1 status.clrsch.com
127.0.0.1 www.clrsch.com
127.0.0.1 clr-sch.com
127.0.0.1 sds-qckads.com
127.0.0.1 status.qckads.com
Edit:
I've tried both methods mentioned below and neither one worked. The corrupted host file comes back no matter what I do
**Update**
I finally ficed the problem. According to the folks over at lavasoft forums I had the latest version of vx2. After waiting for an updated version of l2mfix, using hijack this, and manually editing the hosts file my computer was finally cured, saving me a format and reinstall.
Thanks for the all suggestions.
Edit:
**Update**
