Ok I installed XP Professional yesterday and it seemed to go ok, but when I started installing programs, everything takes a HELLA long time to load. I have to wait around 2 minutes when I turn on my computer for the programs to come out. Anybody know how to fix this problem?
Would be helpful if you post some of your hardware specs, like mobo, processor and such. If you're using a VIA board, check your IDE settings. I had similar trouble with my VIA board.
yea, it might be the 128megs. buy ram fast before prices go any higher. i always used 256 megs. i got 512 now and stuff is even better. it might not be the ram though since i never ran on 128
I had some sluggish performance issues using updated Liveware for XP. I finally ended up reinstalling using the native Live drivers from the disk and it works fine now.
