I have an MSI 694D version 1 with only ATA66 running dual PIII on Windows 2000 in a single partition 30GB ATA66 harddrive. I would like to install a Maxtor Ultra ATA-100 PCI adapter card and an 80 GB harddrive. The second harddrive will allow dual booting with Windows 98SE, both drives is formatted with FAT32 for compatibility.
How can I install Windows 98SE since Windows 2000 is already running? When it's boot to Windows 98, I would like to have RC5 automatically run as well using the same buffers as in Windows 2000. If I give both OS the same computer name and share name in the network, will the other computers automatically reconnect the shared resources? Currently the Windows 2000 RC5 is providing buffers to the rest of the computers in the network. I don't want to interrupt the connection when I reboot to the different OS.
By the way, which of the PCI slot in the MSI 694D dual cpu motherboard is busmastering capable? Should I disable the onboard ATA66 controller? I have the Maxtor 30GB ATA66 drive in the master primary and an IDE DVD drive in the secondary master right now.
Do I need to change anything in the BIOS to allow booting in the drive connected to the new ATA100 controller?
Any help is highly appreciated. Thanks.
