LintMan
Help! I just ordered an MSI K7T266 Pro2-RU motherboard, primarily because I wanted the RAID feature to give me the extra 2 IDE controllers; I'm not planning to run in RAID mode. I would have preferred the Epox board, but the extra IDE sold me on the MSI K7T
Then I came across this VIA Hardware review, which mentions that "you won't be able to use the Promise controller as normal IDE controllers unless you modify the Promise BIOS to enable full functions". Huh? 🙁 Is this true? How difficult is it to modify the Promise BIOS in the way mentioned? Am I screwed?
I can probably cancel the order if I call them back soon, so your input is appreciated!
Thanks!
Thanks!
