HELP QUICK: 9600 AIW Pro Not calling monitor
akeefer
340
Ok, start the computer, but the ATI Radeon 9600 AIW Pro isn't calling the monitor.
Installed the Cataylst Driver, then put the card in. Any help pleasssse????
AMD Athlon 64 3500+
ECS K8T890-A v1.0
512MB DDR400
Do I need some other driver for it to call the monitor? I don't see anything... is it broken???
Let me know!
Thanks!
Aaron
meltdown75
37,548
7
There's a good possibility it is not the card that is malfunctioning.
Try another card, or try the 9600 in another system, and report back.
akeefer
340
The card I took back to Fry's. They tested it, said it was fine, POST'd just fine. So anyway, took it back home to try again, put it in another computer, P4 3.2GHz 478 with an ECS 848-P motherboard, and it works just great! Problem is, this isn't my computer. :-( Any help???!! I really really want a good graphics card for video editing for as cheap as possible, and TV looked like another neat feature. Any thoughts???
akeefer
340
Well found out it just doesn't work on this specific motherboard. Sucky ECS. Anyway, got it to work on all my other systems and it's just awesome, but I need a card for this, so I'm going to sell this.
Thanks anyway!
