HELP! Prolink Fx5900 128mb doesn't work with any force ware!
MechVision
23
The Prolink Fx5900 runs perfect with any 40.xx driver.
But when i try to use any forceware driver (52.13 - 52.14 - 52.16) the card stop and lock up, and then stop and lock up again when playing any 3D game!!
I found a simple solution!When i do a simple overclock (410/850mhz) the problem stop!
but i am trying to sell this card and anybody wants to buy because of this problem!
Does anybody know a definitly solution (without overclocking the card) for this problem?
Sorry my poor english!
thanks
MichaelZ
871
i've had this problem with a 5600. that card would lock up on all 3d applications. the latest drivers at the time was 44.03 and those enabled Open GL to run but not Direct 3D. i took the card back and got my money back, naturally. never knew what the problem was though.
Mem
21,476
13
Hmm very strange problem,anyway you tried it in another PC with the forceware drivers?Also try running Driver Cleaner download it from here (follow the instructions and I also recommend runnig the cab cleaner part as well).
