HELP!!! Project due tomorrow!!!
iamtrout
3,001
Does anyone know how to merge two wav files into one?
Also, does anyone know of any really good, clear, free speech synthesizers (like the AT&T labs one) that I can use on the web that allows me to input something of unlimited length and download the resulting wav file?
Thanks Ananders!!
dOrKuS
785
For merging wav files, do a search on google. You may find what you are looking for HERE.
And for a good speech synthesizer, go HERE.
Hope this helps,
Brian
iamtrout
3,001
Are there any other text to speech synthesizers? The bell labs one is kinda unclear and I need to play this to a whole class.
MeanMeosh
3,805
to merge two wav files easiest, go to Sound Recorder in Windows (remember that? Start Menu -> Programs -> Accessories -> Entertainment -> Sound Recorder), open up one of the wav files (takes a while if the file is big), then click on the location bar to where you want to insert the second file, then Edit -> Insert File and choose the second wav file :) works every time, and i still use it :)
