HELP!!! problem with zip in win2k
elunico
186
i installed the software and drivers from that iomegaware cd (ver 2.0) for an ext parallel 100 zip drive under win2k. After completing the installation it asks me to reboot, so i did. But now i get the blue screen :|, i don't even get to see the win2k login screen. I tried getting in under safe mode but i get the same thing. The message i got from that blue screen is:
STOP: 0x0000007B (some # here)
Inaccessible_Boot_Device
..and then the usual stuff... (check for virus, use chckdsk /f, or reboot...)
i am so mad :| about this. can somebody help, i hope i don't have to reinstall win2k again, for the 3rd time!!
Jul 1, 2000
82
I think you must use version 2.2.1 of the Iomegaware package under Win2k.I'm using it right now no problem.I got the same problem with you when I used the older version.
