HELP!!! Problem with "new" 900Mhz Tbird
hydrobum
302
Ok, consider me a AMD newbie here. I just got a supposedly new 900Mhz Tbird from this vender down the street from where I work.
Here's whats written on the core:
A0900AMT3B
AGFA0049UPBW
94197650599
1999 AMD
Is this cpu made in 1999? If it is, this thing is past 2 years old!!! Also, I found a faded patch on the core which seems
like if some thermal compound used to be stuck on it. I didn't check it that close while I was in that shop but when I got home and looked at under a bright lamp, I could definitely see it.
So, lets assume this cpu is used before. Is this standard practice for a shop to sell used cpus? I really doubt it. I thought they all should have cpu's without heatsinks on them. And I wonder how long my cpu life would last considering I don't know how long
that cpu was used b4. This just sound very shady to me but I want to confirm with you guys on the forum. :|
Thanks!
UPDATE: I see some faint marks on the L1 bridges. Seems like if someone oc this "new" cpu before and used an erasure to rub off the pencil marks. This is definitely a NO NO for a "NEW" cpu right?
Mandlf
22
If that place is down the street, don't even bother trying to install. Just return it. You got screwed. You should have received a new CPU (don't worry about the date, just the condition.) Have heard too many stories about shops selling used as new. You paid for new, you should get new.
lhampel
403
The 1999 on the CPU is the copyright date for AMD's Athlon/Duron
Your CPU was manufactured the 49th week of 2000.
Install the CPU & see what it runs @
