HELP: Problem with cable modem.
limsandy
1,554
I'm currently using @home service. When downloading at very fast speeds, the "pc link" light would go off and I am disconnected. The only way to go online is to restart my computer. Has somebody experienced the same problem as mine?
RPatrick
144
Have you called technical support for @home. They will run diagnostics on your line that may help...
limsandy
1,554
Jeez, the first thing I did was call them up. And if they can solve my problem, I wouldn't be posting messages here.
obenton
2,012
Try to isolate where the problem lies. Check OS event viewer for error messages; do you lose IP address?; check device manager to see if NIC is disabled; can you ping the NIC (localhost); etc.
limsandy
1,554
Apparently, the problem is gone when I am not running mIRC. This seems weird. Does anyone knows why?
ASK THE COMMUNITY
