bluegreenturtle
I appreciate help very much, I just am not getting this worked out.
I have a problem in our office that I can't figure out. Everything was fine until about this weekend.
Here's the setup:
1 Domain controller: w2k
1 File server w2k3
25 workstations, mix of w2k and xp
1 16 port gigabit switch
2 24 port 10/100 cisco switches
Various plotters, printers, including an oce, an hp plotter, an epson hardware rip, a few other printers.
1 usr8200 router - DHCP servicing all the workstations
1 linksys router that services only a machine that is setup as an ftp server.
PROBLEM:
Various users (on a mix of OS) complain about certain programs: Autocad, Powerpoint, Outlook, Acrobat - freeze once you try to print from them. Cannot reopen the program without a reboot. Autocad freezes sometimes with the same problem. Doesn't happen consistently - sometimes things are fine. Main router locked up once over the weekend when nobody was there, locked up 3 more times yesterday morning, seems ok now.
I ran a virus scan on both servers (one server is doing the norton corporate thing) using 2 different programs, ran a virus scan on 4 random workstations (2 were complaining of issues, one was not, one was the ftp server). Found nothing. Virus checkers are on auto on all workstations.
I ran ethreal for a bit on one of the servers but don't really understand it enough...I was looking for tons of noise from one IP or something, I guess.
What should I be looking at? Nothing's changed on the network or any new devices introduced.
I thought maybe it was a corrupt group of files, but that's tested out as not being true.
My only theory is that there is a damaged NIC somewhere that is spewing noise, maybe a printer NIC, because problems seem to be print related. Unless there's some sort of printer virus? :roll:
OH - one thing - NO complaints about internet or network access or speed. Which to me, coupled with the negative virus results seems to make a virus unlikely - if it's spewing packets don't they usually disrupt internet access at least a bit?
Any help appreciated.
Here's the setup:
1 File server w2k3
PROBLEM:
