Help: Printer prints nozzle check but not documents
GR8Madmax
PC info:
1.1ghz celeron
Abit BH6 - SS Bios
512mb sdram
Win 98 SE
Maxtor 20gb HD
Epson Stylus Color 600 - I'm having some trouble printing. The printer prints fine on another computer but doesn't work on my above mentioned PC. It DOES print nozzle check and couple of other test pages but doesn't print from any of the programs I have (word, txt, excel, photoshop, etc.). It seems to be a Windows problem and I would like any and all help figuring out exactly how to fix this. I'm sure this has happened to others so I'm hoping some one knows what's wrong.
Tony
I'm guessing it used to work with this computer.
I'd try removing the printer, then reinstalling it. Doesn't Epson have a tab on their printer properties to check the system status?
morkinva: Thanks for trying to help. I tried pretty much everything with Win 98 including reinstalling printer/drivers. It also said printer status OK and that's why I figured Windows 98 files might be corrupted or missing.
What I finally did was upgrade to Win XP Pro (had a copy lying around) and it fixed what ever was wrong. Once again, I appreciate your reply.
