Friend's PC:
8rda+ with latest bios
2500+ stock settings
512 hyperX pc3200 ram
g4ti4200
350 Watt Enermax PSU (was onsale for 46.99 at newegg - the ones with gold connectors)
His pc was on downloading crap...
then a power outage occured
He pushed the on button, it didn't turn on
So he turned off the computer in the back using the on off button
and then he turned it back on
and then he hit the power buttom
it turned on, but it didn't post
so he turned it off and then took off the panel to see what the motherboard for its error codes
and it read "02" and I beleive that was a memory error
EDIT:
He just reseated the RAM and still 02
Do you think its memory problems? Should I go over and see if my crucial ram will work?
g4ti4200
EDIT:
