Help/Poll: Wireless Home LAN setups?
OliverP
121
Ok, this goes hand-in-hand with my other poll:
I have a LAN with a small 8-port hub in my home-office. I have a cable modem which connect me to the net hooked direct to my main win98 box which I plan to share with my entire LAN. (based on results of other poll! :) )
The problem is that I
m renting, so I cant drill and lay cat5 downstairs to my girlfriend's office, but I want her on my LAN. Now, short of gettign a second cable modem, what are my wireless networking options that will work by using the hub somehow and a proxy of sorts? If you have a wireless or even another solution for this, please share it. Thanks.
(are there any wireless LAN hardwares out there which will go into hub instead of my usb/pci??)
