no 100% sure which 1 gtx 770 need chek laiter cant now
its reach automatically i dident change anything
14cm is silent fan and ye is ventilated
so I can get a better look and make a final determination..
It's not overheating, it stays at 52'C under load. D:
KaRLiToS i uninstal all drivers rebooted and clear with CCleaner and instaled last version
337.88 and after 10min playing game = no signal
i have already dat problem long time they dont know how to fix at serviceBut like I pointed out here https://forums.geforce.com/default/...-responding-and-was-recovered-successfully/1/ it seems like a recent issues with NvidiA.
Please give DDU a try.
-Uninstall your Nvidia drivers
-Reboot
-Run DDU ( it will do everything for you, just need to check the Nvidia driver removal)
-DDU will restart in safe mode and proceed to full driver removal
-Reboot
-reinstall driver (Try 334.89 if you can)
CLICK HERE TO DIRECTLY DOWNLOAD DDU
