- Jul 25, 2005
- 73
- 0
- 0
**EDIT*** Ok, so when trying to get the xp90 on...it rocked and I wound up having to lift it off. Should I clean both or leave the heatsink on and not worry about it?
Originally posted by: JBDan
Yes I did. Could get oil from your hands on either while handling them. I just used the highest % isopropyl alcohol I could find. Like .99 cents at Eckerds I think.
Originally posted by: cazicthule
Think I should place the processor in the computer before I clean it to avoid any chance of bending pins while cleaning it?
99% isopropyl is a good bet![]()
yep, your dont need there stuff dont listen![]()
