The fans going on and then stopping is a sign there's a problem stopping it from starting up. The fans are a symptom of the problem not a problem to be fixed.
For it to be stopping that quickly i'd think it was a power issue, check you've got the motherboard mounted correctly (remove it and check the mounts) and then check there are no wires causing short circuits. make sure the graphics card and RAM are correctly seated in thier slots and try again.
In future it's best to know the following, if you don't have a clue then fair enough, but otherwise:
What brand of PSU do you have?
What model of motherboard do you have?
One stick or two of RAM?
What geforce board do you have?
