help please
p3r2y
20
Something went awry when i installed a second 7800gtx and i accidentally ripped out the cpu and bent all the pins. I'm sure the mb is damaged. I'm replacing the cpu and motherboard, but im wondering:
is there a possibility that my ram or my video cards could have been damaged through this system failure of the cpu/mb? Is that possible? PLZ help.
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
Did you have the computer on somehow while you were doing this? If not, then only the physically damaged parts should be at risk. I'd definitely take a look at everything though, but they should be alright.
Tas.
addinator
160
just a question.. how did you manage to rip out the cpu? and I highly doubt that if you, like said above, only phsically damaged the mobo/cpu it would harm the video cards or the ram. thats assuming you didn't like send an electrical spike or something but i would hope you didn't have the computer ON while installing the second card.
p3r2y
20
well i ripped the cpu out because i was having problems, and i meant to take the hsf off, but the cpu just came out with it with at least 6 or 7 pins badly bent. the reason i was wondering is because the problem i was having was the the system would start up and then turn off immediately, which turned out to be a grounding issue, then when i took everything out of the case and gave it a whirl, i got no display from the monitor. i thought sli was definitely the culprit, but i tried it with one video card, and even an old pci video card, and i got no display either way. so maybe from the grounding the motherboard chipset died or something of that nature, not allowing it to give a signal to the monitor from the pci-e lanes. I was wondering if during that process my precious 7800 gtx's could have been damaged from those grounding issues/whatever. i highly doubt it because when i had grounding issues with an old intel mb, as long as the mb worked, the video card and ram worked fine. I just tested the ram in an old intel platform and all of it is recognized, so im ok on that.
DaiShan
9,617
You are probably fine, assuming the computer was off while you were working on it, and you properly grounded yourself. Replace the motherboard and cpu.
p3r2y
20
ok its just good to know that my vga's arent damaged because that would be really bad, as they are the most expensive hardware in my setup.
