Soltek sl-75 Kav
1200 t-bird
2 pcs.pc133 256mb memory
ibm 30 gig hd
300w sparkle ps
ati raedon 64ddr
xp pro
While messing around Ocing ie bumping fsb,cpu voltage, mem., voltage, multiplier ,and with all the rebooting to go with I started experiencing several different errors while trying to reboot , GPF ,missing files and just blank screens with the hd running. I tried replacing files , running XP?s recovery console , repair install , even reformatting and reinstall xp (it never completed) .
Replaced HD ?no help , pulled nic card and 1 stick mem. system boots and xp install completes, replace nic- get GPF on reboot ,I remove nic ?reboot fine- replace other stick mem- missing files error on reboot- remove mem- boot fine . I then swap known good nic and get good boot and network setup starts ? reboot after and blank screen. I proceed to swap mem with known working mixed results and no network with ether card.
Any ideas ? Trashed mobo,PS,-floppy or case screws?????
Thanks
1200 t-bird
ibm 30 gig hd
300w sparkle ps
ati raedon 64ddr
xp pro
Thanks
