bushwickbill
I have been on a mission for about a week to get four 750GB Hard drives deleted or changed into regular hard drives. I have been running into issue after issue, and now a new one. I went to the ASUS support site to get the RAID drivers for my Server MOBO, I downloaded three of them to be sure I got the right one.
So I boot up my Server (Which has a damaged OS so i can't just start the OS and use it) and put the Floppy with Said RAID drivers on it. I got a message stating 'Not a system disk please insert system disk and strike any key'.
So i then put my WIN XP disk in to go through the steps as if i was installing window. Like before it said 'Could not detect or find any hard drives please hit F6 to install SSCI Drivers'
So I put the floppy disk in to load the RAID drivers and i get this Error message!!
"the file txtsetup.oem could not be found press any key to continue"
What the heck does that mean? I though i finally had everything i needed to delete this RAID setup and now I have no idea what this error message means.
I am using a ASUS P5M2-M Server MOBO with a XEON 3070 CPU on it.
Is there no such thing as a program you can burn onto a CD or DVD and put into your Rig to completely Delete everything on your hard drives including the RAID setup?
Because this process of getting the right RAID drivers on to a Floppy disk just isn't working.
Does anyone know for sure which driver I need to put onto a floppy disk so I can load this RAID storage utility so i can delete the RAID setup?
http://support.asus.com/downlo...age=en-us&model=P5M2-M
That link is to the ASUS support site for the Server MOBO. So which one do i need to down load?
Because I already grabbed the three SATA ones
Version 6.0.1.1002 2006/12/12 update
OS Win2K / Win2003
Description Intel Matrix Storage Manager driver V6.0.1.1002
Intel Matrix Storage Manager driver V6.0.1.1002 for Windows 2000 with SP4, Windows Server 2003 32 bit.
File Size 178.36 (KBytes)
OS Win2003 64bit
Intel Matrix Storage Manager driver V6.0.1.1002 for Windows Server 2003 64 bit.
File Size 259 (KBytes)
Version 4.2.1011.2005 2006/12/12 update
OS Win2K / Win2003 / Win2003 64bit
Description LSI MegaRAID IDE Driver V4.2.1011.2005
LSI MegaRAID IDE Driver V4.2.1011.2005 for Windows 2000 with SP4, Windows Server 2003 32/64 bit.
File Size 596.91 (KBytes)
Those are the right one to pick from right?
I am just unsure of the Exact one to get.
Please I need some help with this frustrating issue.
But as i stated, I already copied all three of those drivers onto a floppy disk and it did not work. Do i need to do something else for the Server to read the floppy disk?
OS Win2K / Win2003
OS Win2003 64bit
