I have decided on the following configuration for my new computer:
Now, I am trying to choose my Power Supply Unit.
How many Watts would I need? Power Supply Calculators @ http://www.jscustompcs.com/power_supply/&e=7413 and http://www.utcache.com/power.asp&e=7413 tell me that I need more than 350W PSU or 400W PSU.
But, my friends say that this configuration would NOT need more than a 300W PSU.
Please help me. What PSU specification to go for? 300W or 350W or 400W?
Thanks all in advance
The HIGHLY TECHNICAL forum is not for purchase advice.
AnandTech Moderator
Athlon XP 2500+ @1833Mhz "Barton" core - (Retail) Box Pack (with heatsink and fan) - 333FSB
A7N8X-Deluxe Motherboard (with Soundstorm) PCB Version 2.0 or later {I heard this one takes up a lot of PSU Watts}
Gigabyte R96P128D (Radeon 9600 Pro) AGP card {This one too seems to take up a lot of PSU Watts}
333 Mhz 184-pin "CAS Latency 2" Unbuffered non-ECC (non-registered) Double-sided x8 or x16 256 MB DDR x 2 = 512 MB DDR [Run in Dual-Channel mode at most aggressive timings]
Seagate 80 GB/7200 rpm HDD Ultra ATA/100 Barracuda HDD
Samsung 52x Combo Drive (16x DVD, 52x CD Rom, 52x Write, 24x Rewrite)
Samsung 52x CD-ROM Drive
Samsung SyncMaster 753S 17" Monitor
Samtron 40Bn 14" Monitor (Dual-Monitor Setup)
Creative Inspire 5200 (5.1 - 6 channel analog speaker)
PixelView PlayTV Pro Ultra w/FM (PCI TV Tuner card)
CanoScan LiDE 20 {This one is USB Hub Powered. So, takes power from PSU}
Lexmark 3200 Inkjet Printer {This one has 2 cables. One is directly connected to the UPS while the other goes to the back of the case. So, I doubt if it will take any power from PSU}
D-Link DFM 560ES (External 56k Modem) - {Connected directly to the UPS and also to the back of the case}
SmartMedia card Reader/Writer {Again, USB Hub Powered}
1.44 MB Floppy Disk Drive
Frontech Fantasy Pad {Again USB Hub Powered}
Typhoon Ramses Joystick {Gameport}
Logitech 3-button Optical Scroll Mouse {Again, USB Hub Powered}
ATX Cabinet w/ 2 80mm fans (1 in lower front - Intake fan + 1 in upper back - Exhaust fan) w/ Front USB connectors
AnandTech Moderator
