Thanks
gxsaurav for your reply.
First up, I do not consider it as high setup. In fact, I am squeezing the configuration (and money) to the minimum I need and can afford. 2 Monitors is because, I have one spare 14" Samtron 40Bn from my Cyrix PC. And, 2 gamepads? No. It is one gamepad and one joystick and they are very cheap. Both together costs about Rs.1000 (US $ 20). I can't even afford a P4
But, then, even if will, I will have to buy a seperate sound card as not many Intel boards have nice ones, let alone come near to A7N8X-Deluxe's onboard nVidia SoundStorm.
But, I don't quite think so that the clock speed will not be enough, cause, of course, XP 2500+ is clocked at 1833Mhz, but, it has good L2 cache and in benchmarks really "beats" P4 2.4 in many tests. (tomshardware.com and anandtech.com). But, still, I think 1833Mhz will be enough for me, as I won't be running more than 2 apps at the same time. For example, GigaStudio 160 and Nuendo would run simultaneously in that, wouldn't it?
And, for the case, as I had said before, I am squeezing the configuration to meet my budget. So, I am looking for a case + psu @ less than Rs.2000. And, I was wondering if I could manage a 400W one withing that. You said it cost you the same amount in total. This looks cool. Can you provide more info on that?
And, of course, looks don't bother me at all! And, mediocre looking case is fine...
And, the temperature or cooling - An average one is fine for me... About 35°C is fine. Will this mean, I need no more than 2 chassis fans and 1 cpu fan (that comes with the cpu itself)?
And, I have one more doubt. A7N8X-Deluxe comes with 3 fan connectors (headers). One for CHAssis fan, one for PSU fan, and one for CPU fan. You say that the PSU will come built-in with 1 (exhaust) fan. Will this fan occupy the fan header in the mobo or will it take power directly? If it will take power directly and the one fan header (PSU) will be free, will it be fine if in that header is connected the second CHAssis fan (assuming that in the other 2 headers are connected their respective fans)?
And, thanks
StraightPipe,
CryHavoc, and
GreatDaleness for your posts...
Atlantean - No, it is one CD-ROM drive from my old computer and 1 DVD Read + CD Read/Write COMBO drive.
alkemyst - What you had said about "drive rail" seems very important but, I couldn't understand a bit about them...
I tried Googling 'infinite loop' and 'power supply' but no avail... Does it mean that I should not buy cases that are "marked as 'for P4'"? Does 2500+ "Barton" unlike P4 as regards the power supply? I am confused... I would be very glad if you would kindly put me wise...
Waiting for all your replies...
Thank you,
DrLynx
