- Jan 23, 2000
- 217
- 0
- 0
I have been trying to figure this out for a week.
I set up a new computer for my dad. I installed a new oem PCI64 sound card. Loaded the drivers. Upon restart. I received the following message:
"The Creative Sound Blaster PCI64 driver cannot load the MIDI waveset. MIDI playback has been disabled.
I first went to the web and got the latest drivers, installed them. No help.
I can go into System Properties, select the sound card and under properties there is a section to add a MIDI waveset.
I do this, go to the installation CD and there is a waveset there. I load it. The properties then show it.
I shut down and restart. Same thing..... And when I go to system properties in the "add midi waveset" window, there is no waveset listed. It seems the software cannot "hold" the waveset after I load it.
There is a check box for "lock waveset" I did that and NO help.
Any Ideas/suggestions would be appreciated.
Thanks
CyBOrz
Thanks
CyBOrz
