I am trying to put together a multi-OS boot system.
I've got DOS loaded in the C: drive/ active partition (47MB). I've used DOS fdisk to create extended partition. I've used DOS fdisk to create logical DOS partition in the extended partition (2GB for files to be shared by DOS and Win 98SE); fdisk has denominated this drive E:. Both those first two drives use FAT 16.
I then used Win 98SE fdisk to create another logical partition in the extended parition. I enabled large disk capability (so as to be able to use FAT 32). Fdisk denominated this drive F:.
Next, I booted off the Win 98SE CD (OEM - not upgrade) and ran setup. At first, all was okay -- then, I started getting repeated messages that Windows could not find files it wanted to copy to the HD. The default choice was NOT the drive where the CD was, but the E: drive.? I could not get the program to locate the necessary files, even when I directed it to look into the CD.
I pressed ahead, continuing setup without those files. I was then able to get the computer to boot up from Win 98SE on the HD (without a lot of drivers and with a bunch of yellow marks in the hardware list).
Then I booted from OEM (not upgrade) Win XP Pro SP1a CD. I added another logical partition, selected NFTS. and continued with Win XP setup. Then, I ran into a similar problem as described above -- the setup program could not locate files it wanted, and all my efforts to get it to find them on the CD were to no avail.
Any help for this lost noob?
