Ok, I'll try to make a long story short:
The OS (XP Home) was corrupted on my Toshiba Satellite 1105. "ntoskrnl.exe" not found is the error. Windows will not boot. I cannot repair the installation using the XP CD because Toshiba only gives recovery CDs that use Ghost images, not the actual OS.
So, I need a way to recover a few critical files off the laptop harddrive before I format and reinstall. Luckily most were backed up. I can boot to DOS using a boot disk, but the drive is in NTFS so I can't access it.
Is there a way I can access the files in DOS using an NTFS driver? Or a way I can access the drive over a network from my XP desktop?
Any suggestions? I really don't want to spend $60/hour to go to the data recovery place.
Thanks!
Thanks!
