HELP! Please help me on my kt7/duron600, it suddenly can't power.
zane
28
My computer suddenly can't work. I installed it about three month ago using abit kt7 and duron600. It works fine until yesterday. When I turn on, it doesn't response. The cooling fans of CPU and power only rotate several circles then STOP. After I change video card and memory and power even the CPU, it still can't work. I suspect there is something wrong with the motherboard. But I feel really odd cause I DID NOT touch computer. My computer just suddenly doesn't work
Did someone meet similar situation? Or give me some advice.
Thanks.
ALstonLoong
1,627
HI ,
Well...i experience with motherboard failure before but my case fans still work.I was wondering why yours wont work.Well...i think you need to do a few experiment.... like ...change the powersupply ....or did you assemble correctly the power cord.
zane
28
Yes, I change power supply. It doesn't work. in fact I change memroy, cpu and video card. All I got are same: the fan only rotate several cycles and stop, no beep, no any response.
Losty
1,136
could be the board...last time this happend to me ... the power supply cord was not completely pushed into the board...might want to check if something is preventing it from locking in place...
