HELP PLEASE HELP HOW DO I CLEAR BIOS????
trOver
so i tried to overclock my E6600 too much. (didnt give it enough voltage, so now it wont post) The computer turns on, but i get no post or video. Obviously, i need to clear the bios. BUT HOW???
I have an ASUS P5W-DH Deluxe, and i found no bios jumper???? what should i do???/
thanks in advance!!
EDIT: can i just take out the battery for like half an hour? wont that clear the bios aswell?
Yes, taking out the battery will work. Half an hour is overkill, a few minutes is more than enough. Obviously, be sure you're grounded and have the system unplugged.
