Originally posted by: Bozo Galora
Set rocker swith on PSU (if it has one) to "0", Unplug the PSU from wall, short the 1-2 cmos pins (pin 3 doesnt go anywhere) with the jumper and leave it there, pull battery and wait an hour. Put battery back in, unshort the pins, plug in PSU, put rocker on "1" (Note that plugged in PSU's that are "off" still have trickle voltage)
Get a PCI vid card from somewhere, pull your PCIe card, and put it in. Buy one stick of cheap high latency (crummy) RAM (Like 512MB corsair value ram) that ris specced to run at STOCK VOLTAGE (1.8), pull your RAM and put in cheap stick. If it boots, immediately go in bios and set failsafe defaults and boot to XP.
If that doesnt work, do it again, but wait 24 hours. I know it sounds crazy, but sometimes 24 works when 1 doesnt.
Do you even know what the motherboard looks like and how it works?
The CMOS jumper, or BIOS jumper, is ALWAYS jumpered across 1-2. That is its NORMAL setting, so "shorting" 1-2 pins is doing absolutely NOTHING.....it's always set that way.
Shorting the CMOS pins to 2-3 actually does do something....it enables the maintenance menu to be accessed in the BIOS. Pin 3 does indeed go somewhere......unlike what you've mentioned. Removing the jumper completely from the pins actually gives you what you are looking for in your misguided statements above.
But, after a bad OC in the BX2, moving the jumper to the 2-3 setting always has enabled the board to boot to the maintenance menu in the BIOS with essentially default settings.....never have had an issue with it refusing to boot set like that.
Maybe you're confusing the BX with the BX2 boards. The BX2 uses both settings on the pins for different uses.
PS.....many, many power supplies, when turned off on the rear, do NOT trickle power to the board.....this has been established by using a multimeter on the ATX power connectors and comparing the on vs. the off setting on the ps.
But, removing the plug from the back of the power supply, a much easier done thing than trying to unplug from the wall and accomplishes the exact same thing, is always recommended. I also, after unplugging the power cord from the power supply, hit the power button on the case to discharge any saved elec. in the ps's capacitors. Works every time.
