Just installed Windows XP Pro. Was running Win98 SE and network worked just fine.
System:
ASUS K7V motherboard latest bios 1007
AMD Athlon 650MHz
Nic cards tried - Dlink DFE-530TX+, Linksys 10/100, USB Netline.
The cards appear to configure OK (recognized and 'working properly' in Device Manager).
To troubleshoot, I connected a laptop and this system to a linksys router (no WAN connection). Opened the Active DHCP table in the router and can see the new XP appear in the table if I repeatedly hit the refresh key while attempting to renew or repair the LAN connection. It shows up for a second then disappears.
So, I know it is requesting an IP from the router and the router is giving it one. But it never acknowledges receiving it! It eventually times out with the APIPA address of 169.254.x.x and the message - " An error occurred while renewing interface Local Area Connection : unable to contact your DHCP server. Request has timed out.
I've changed cables, tried the router, another XP machine set up as a router, and even a crossover cable between
the laptop and this machine with static IP configured. Still no joy!
Anyone got something new for me to try? Like I said, it worked with 98SE, and if I reinstall 98SE I know it'll work again. Something to do with XP but I've run out of ideas.
No firewall installed. Cables less than 10'.
Anyone got an idea why this is happening? Some other troubleshooting tricks to try?
Thanks!
System:
AMD Athlon 650MHz
Thanks!
