Help please, ASAP
jimmyj68
573
Doing a build for brother and will give him ability for external backup. Just took delivery of a Rosewill external enclosure model RX35-AT-SU3. No instructions came with it and I can't even open the unit to put in a HDD. Anybody out there had one of these? How the heck do you get it open?
airdata
4,987
Looks like it has screw holes on the back side where all of the connectors are.
jimmyj68
573
You are right BoomerD- I should have known that all those empty screw holes meant the thing was force fitted and all I had to do was pull - but I was reluctant to pull on it too hard. The rest is falling off a log (I hate getting bruised).
Thanks boomerD
