First post to the anandtech forums but long time visitor...
I just upgraded from a 9800Pro to a BFG 6800GS/OC and have the following questions:
1) UNLOCKING PIPES:
I read the entire link of how to unlock pipes here - http://forums.anandtech.com/messageview.aspx?catid=31&threadid=1500237
However, when I get to step 4 - "navigate to the NVStrap tab. On it, toward the bottom, you will see a check box that says "Allow Enabling Hardware Masks." Go ahead and check it" - I find that my "Allow Enabling Hardware Masks" is greyed out as is everything on this screen. Any idea why and what to I should do so I can enable hardware masks? This is a key step to try and open the additional pipes on the card.
2) DRIVERS:
I downloaded the latest NVidia 81.98 forceware drivers which are supposed to recognize the 6800 GS and 7800 GS cards but they DO NOT recognize my 6800GS. I have to use the drivers that came with card and they work fine. Just wondering if this is expected and should I be concerned that I wont be able to use future NVidia drivers? Also, is there a forceware driver set that other 6800GS users have been able to use? I would hate to be stuck with the drivers that came with the card forever...
3) PERFORMANCE:
My default 3dMark05 score at 1024x768 went from 2742 (9800Pro) to 4467 (6800GS). This is an increase of 61% which is very nice but I was hoping for a score above 5,000.
Should I expect better performance considering my system specs are:
Athlon XP 2700+, 1GB PC2700 Corsair High Performance memory, and an ASUS NForce 2 mobo
4) BF2 Graphic Settings:
Will increasing the textures and lighting to high put an additional load on my 1GB of system memory now that my card has 256MB of onboard memory? Also, has anyone found a sweet spot for graphic settings running the 6800GS with BF2? I have everything cranked up to high at 1024x768 with 4xAA and I do notice some slow down at times but then it gets silky smooth at other times. I have some more testing to do with settings but I am thinking somebody has already found the best graphic settings with smooth gameplay.
Thanks in advance for your time and assistance!
1) UNLOCKING PIPES:
2) DRIVERS:
3) PERFORMANCE:
