Some monitors come with both analog & dvi inputs... even though in the end I think its analog anyways. 🙂
The trouble is finding a good! one that does. 🙂
I never heard of a CRT that comes with DVI. DVI is a digital input, and CRT's are inherently analog. The only monitors I know of that come with dual inputs are 17 inch and above LCD's.
My Nec FP1350X 22" CRT has DVI, and man I love it. It looks GREAT! Of course, the analog cable that comes with the monitor is a thin POS, but the DVI RULES!
Given that DVI "Hz" is very different from analog "Hz," you should *only* run LCDs at 60Hz with DVI. Most units will mandate 60Hz in documentation (if not a big ol' sticker when you take it out of the box).
