HELP!! Pin 6 on my vga monitor cable broke off!!
monkied
183
How do I fix this??!!! The cable cannot be disconnected from the monitor, so I can't replace it. Pin 6 is actually used for Red Ground. Can anyone help??
JonnyDuke
369
Go to Radio Shack and buy a new connector then carefully cut away your old one, strip the wires and connect the new d-sub. That really is the only gauranteed way of making a permanent fix.
dkozloski
Sometimes the grounds are all connected together. Try it and see if it works anyway.
monkied
183
It still works, but you'll see a slight double image of red because of the noise I assume. I guess I could try reconnecting a whole new d sub connector, but damn thats a lot of trouble. Any other suggestions? I'll redo a new connector as a last resort. Thanks for your help.
