Title basically states it. But to clarify.
I have five items in my network cabinet that I want to have power for about 1 hour after power loss.
The five items are:
Cable modem: (Arris CM820) rated at 5-5.5 Watts
Router : (Linksys E3000) rated at 7 Watts
Switch : (D-link DGS-1024D) rated at 13.5 to 30 Watts
POE injector : (12 port) ~120 Watts
OOMA box : rated at 5-8 Watts
So the total for the above is a hair under 200 Watts.
I'm looking for a quality UPS that will run those items for about 1 hour.
The modem, router, and ooma need to be maintained for phone service during power outage for emergency purposes.
The switch and POE injector need to be maintained for security camera during "theft" power outage. A laptop will be used to record during power outage under normal battery power.
So what do you recommend?
Space is a little bit of a premium. At least one dimension has to be under 7 inches😵
The five items are:
