help picking out a hsf
jswjimmy
ok im getting this mobo link and this ram link but now i need a hsf to get my xp 1800 to 2.2 ghz. can some one show me a good one. stick to newegg, clip on, and under $50. thanks
Originally posted by: Abzstrak
ThermalTake Volcano 12+
have my barton core overclocked to 2.5GHz @ 1.825V, running at 36C idle, 43C under load......Newegg is alittle high though, bought mine local for $26.95 (at axion, www.axiontech.com)
More Info on Volcano12
i did some looking in to it and is the same price. Its a litle worce than the slk900 but not by much. comes with a fan controler. and its quite, ok abzstrak you won me over i change my mind im going with the volcano12. thanks
the Volcano 12 is an excellent heatsink one of the best! check out this review vs SLK-900A review
AMD Athlon XP T-Bred B DLT3C 1700+ @ 2.3GHZ (1.775v) 400FSB = 3200+
Abit NF7-S V.2 (nForce2 U 400)
Corsair TwinX XMS 3200LL 512MB @ 2-3-2-6 (2.6v)
Sapphire Radeon 9500 Pro 128MB
Antec TrueBlue 480W
Thermalright SLK-947U with 92mm Vantec Tornado @2800RPM
Maxtor 91531U3 15GB
2x Western Digital WD400BB 40GB serials
Antec PlusView 1000AMG
Cambridge SoundWorks MegaWorks THX 550 5.1
ya thats useing the fan from the volcano not the slk900a. if it had the fan from the slk900 it would totaly win (but not by a lot)
so buy a tornado fan and replace it on the volcano, you will have an extra fan🙂
Antec TrueBlue 480W
Maxtor 91531U3 15GB
true but then i cant use the fan Controller. that the reason why i switched
