1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
mostly gaming (WOW, any future blizz games, occasional fps)
as a tivo as well.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1000-$1100
3. What country YOU will be buying YOUR parts from.
US
4. IF YOU have a brand preference.
I want to go intel cpu for this build and quad
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
reusing dvd/cd drives only
dualtv card.
6. IF YOU have searched and/or read similar threads.
yes
7. IF YOU plan on overclocking or run the system at default speeds.
running at default, dont plan to overclock
8. WHEN do you plan to build it?
within the month
I will be sticking it all in a antec p180 case
http://www.newegg.com/Product/...x?Item=N82E16811129154.
Intel BOXDP35DPM LGA 775 Intel P35 ATX Intel Motherboard - Retail
http://www.newegg.com/product/...p?item=N82E16813121314
Intel Core 2 Quad Q9300 Yorkfield 2.5GHz LGA 775 95W Quad-Core Processor Model BX80580Q9300 - Retail
http://www.newegg.com/product/...p?item=N82E16819115043
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 996557 - Retail
http://www.newegg.com/product/...p?item=N82E16820146692
MSI NX8800GTS 512M OC GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/product/...p?item=N82E16814127325
PC Power & Cooling S610EPS 610W Continuous @ 40°C EPS12V Power Supply - Retail
http://www.newegg.com/product/...p?item=N82E16817703005
Seagate Barracuda 7200.11 ST3750330AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/product/...p?item=N82E16822148298
mostly I want a stable system. I've read the intel motherboard requires 1.8v memory? would an abit ip35 pro or the gigabyte ep35-d3sr series be more reliable/compatible with more vendor memory? and with the q9300 will ddr2 800 speed memory be sufficient?
I've read the duo is better for games but would rather have a quad (unless the difference is huge) which it doesnt look like it. I also want to stay away from antec power supplies(had bad luck). also if the video card vendor is alright? or are the xfx/bfg ones better?
thanks for any input
as a tivo as well.
$1000-$1100
US
dualtv card.
yes
within the month
