- Oct 4, 2002
- 2,188
- 99
- 91
Current Set-Up:
Palomino 1600+ O/C'd to 1.75Ghz @ 333Mhz FSB
Volcano 5 HSF Combo (Max. CFM:32)
SLK3700AMB w/ stock 120mm fan (Max. CFM: 107)
VCore hasn't been changed (bought used from Insane3D) from what it was when I got it. MB = Epox 8RDA+
Now, this current set-up is pretty loud for my tastes, so I'm looking into replacing the Antec 120mm fan with a Vantec Stealth. This halves my CFM to Max. 57CFM. The only way to get a quieter HSF is to upgrade the HSF to one that supports larger fans. I haven't decided on the which heat sink I want yet. Any suggestions (remember I'm looking for quiet...not silent...but quiet). Anyhow...the real question is this...
Will the loss of 50 CFM impact my temps a whole lot? (obviuosly it will affect it some). I've got some temps from 5.5 hours of Prim95 I'll post when I get home.
EDIT:
Temps as relayed by the BIOS of the EpoX 8RDA+:
Ambient: 25C
CPU: 49C
This was after 5.5 hours of Prime95. Now, I could have SWORN I've seen higher temps before while checking other things...so...I'm going to stress test this baby overnight (Prime95 + NAV Full Scan every hour). When I get up, I'll check for errors, shut'er down and fire'er up and check the temps. I will post them when I get to work.
P-X
EDIT:
Ambient: 25C
CPU: 49C
P-X
