Help Picking a Motherboard
Richb1492
I am about to start a build and really could use a lot of input on my board choice.
I was looking at the budget system on the main page and saw a lotta good reviews on it and far as overclocking and such.
The Biostar I945P-A7 seems really good for my needs but here i need advice.
I have 2 ata drives i was going to use to build my new system . But this board is sata.
Should I buy new drives?
Pick a new board?
Buy an ata to sata convertor.
Thanks for any comments
The reviews I checked quickly with google indicate it does have ATA. Might wanna check your sorce(s) again.
Fern
That board should be fine. I can't think of any motherboards off the top of my head that *only* support SATA and not IDE drives. So your old drives should work no problem.
