Help! PCIe Suggestions?
Dr Noob
hey all!
i am currently upgrading (new m/c) as follows...
amd64 3500+ (90nm? or older newcastle?)
dfi lanparty nforce4 ultra-d
2x256mb kingston dual channel mem
etc.
any recomendations would be great.
but my main concern is my graphics card, there are sooo many munufacturers out there i just dunno where to start! im thinking of a 6800gt pcie.
which manuf. would you suggest? any and all help would, well...help.
Thanx everyone!
Welcome to AT.
Any reason why you're only getting a 2x256mb kit when you can get a gig for $100 or less?
with the ram, i figured id get better quality rather than quantity, after all i have always gotten by playing stuff like H-L2 on max with my ol' rig which had 512.
amd 2800+
512mb ddr400
dfi mobo
geforce3 ti500 64mb
do you think its worth going for cheaper ram and getting more?
with regards to that BFG g-card, it looks sweet! i haven't heard much about BFG though, is it worth the pricetag? i'll do some more research on it for sure.
thanx guys.
amd 2800+
512mb ddr400
dfi mobo
geforce3 ti500 64mb
thanx guys.
with 1gb things will be so much better also whats your budget so we can better help you
well for memory i am willing to pay up to 120, but only if its really worth it,
graphics card, id like to spend in the region of 300 - 380 give or take.
i figured to spend more on the rest of my rig, like my core components such as video card, motherboard and cpu, cause ram is easily upgraded and i can do it at anytime but i am willing to fork out the cash if you think its worth the initial expense?
Personally, I'd save myself $80 -$100 and get an x800xl instead of the 6800gt. Then use the savings towards more ram.
i must admit, i'v never been much of an ati fan myself, but id like to know if you think the x800xl is just a cheap alternative to the 6800gt or if its really on a par, cause the savings would definately be worth looking at if it matches up to the nvidia. but then i still have the problem of which manufacturer to go for?
Take a look at Anand's X800XL article from a few months back. It really is a worthy alternative to the 6800GT, and quite a bit cheaper too. 🙂
thanx 4 all your help guys,
i looked at that rosewill x800xl, looks good, is it a trust worthy brand though? people seem to like the asus aswell, i think its alot more expensive though. i really do like the rosewill though, has anyone had any experience with them? Good, bad?
Originally posted by: j511180
x800xl vs 6800gt
i had a look at that article and am impressed with the x800xl but my only concern is wether its poor performance in doom3 is a problem that will occur with all the games based around dooms architecture and has the prob been sorted out in the latest driver releases or is it just a glitch in doom?
