Specs
Vista Home 64
Intel Q6600 @ 2.4Ghz
ASUS P5K
Club3D 8800GTS 512
4Gb Crucial Ballistix 8500
2 x WD5000AAKS
Audigy 2 ZS
2x NEC Optiarc DVD RW
Thermaltake Purepower 430W
I recently moved from the UK to Brazil and took most of my PC components with me. When i arrived i bought a new Thermaltake Purepower 430w PSU for the change from UK 240v to south america 110v.
I have rebuilt my PC and it loads into vista 64 but when i play a game it immediately resets the PC. So i downloaded Prime95 to stress all four cores and it also resets the PC either immediately or after 1 minute.
So i went back to basics and removed 3 sticks of ram, network card, DVD RW, HD and reduced RAM timming, added voltage to the CPU and DIMM. Then i used memtest86+ and it tests fine overnight with zero errors and no restarts.
I thought i solved the problem until i tried prime95 again in vista and again it still restarts during games and immediately in prime95. My temps are also ok CPU is at 40c full load and mobo 35c.
So i am out of ideas now, the only thing bugging me is the PSU issue as this is the only changed component since the move form the UK to brazil. But my PSU in the UK was a Tagan 400W and i was running all four 1 gig sticks of ram (4 gigs in total), and extra DVD RW and an extra HD and the system was fine. This new PSU is slightly higer 430W and its a good brand (Thermaltake).
Also i have noticed that people here tend to use these things called Estabilizadores (Stabilisers) which i am not familiar with, but i think they protect against over voltage, but could i have an under voltage problem.
I also used speedfan to test the rails and it reports as follows...
Vcore 1.26v (i set this to 1.30 in BIOS)
+12v 11.35v (idle in vista 64)
AVcc 3.28v
So i am thinking voltage problems or simply something could have damaged during the move.
could anyone help!
Vista Home 64
ASUS P5K
Club3D 8800GTS 512
2 x WD5000AAKS
Audigy 2 ZS
AVcc 3.28v
could anyone help!
