This weekend as I was playing a game on my PC I consistently smelled that "hot PC" odor. I use an old Corsair H50 in a pull configuration with a front case fan pushing and a top case fan in pull mode. So I shut her down and noticed that the radiator exhaust fan filter was caked with dust and that maybe this was causing the heat issues as the air flow out was blocked. The radiator itself was hot to the touch.
So I unscrewed everything and washed out the filter and when I turn the PC back on it shuts off after a few minutes. I reboot and I get a high temperature warning. I then quickly boot into the BIOS and load up the HW Monitor to see the temps in real time. The temperature was rising 1 deg per second! So I shut everything down and lo and behold, the H50 had somehow come loose from the CPU. Caked-on thermal paste was all over the motherboard. So I twist the H50 back in place and tighten the bracket to the MB as tight as it could go thinking that this would solve the problem. No dice. Temps were still rising 1 deg per minute up to 70C when I finally shut it down. So I'm at a loss here.
The H50 is in good contact with the CPU but it's behaving like there's no heat sink at all. I could feel the H50 pump working when I turned it on, so I believe its still working. The only clue I have is the caked on thermal pad that peeled off. There was still a layer on the H50 and the CPU heat spreader so I assumed that this was good enough. Will cleaning and applying a new layer of thermal paste solve my issue?
This is odd, I thought that at least with a heat sink on the CPU, bare minimum the temps would stabilize. But the temps keep rising like there's nothing on the CPU at all. Can this be due to a lack of thermal paste? A rudimentary understanding of thermal dynamics says no, but I thought I'd ask anyways since I've never applied a heat sink to a CPU without thermal paste/pad before.
