HELP! PC intermittly restarts when onboard gfx driver is installed
Mitto3k
Hi all,
The problem is this..........I have built 3 PCS the specs are below
Asrock P4i65G Motherboard
2.8Ghz Celeron D
1GB RAM (2 x 512 3200)
160GB SATA Maxtor
DVD/CDRW Drive
400W PSU
On ALL 3 systems the PC restarts when the onboard graphics driver is installed (Intel Extreme Graphics 2 - 82865G). I have tried the drivers from the CD,AsRock Website and the intel website all do the same. Restart. I have tried different verison of windows with no joy.:(
When it restarts i get a blue screen with the following error
Error code 0000007f, parameter1 00000000, parameter2 00000000, parameter3 00000000, parameter4 00000000.
Everything else works fine on the board sound, usb etc but i cannot understand why this happens and the same on ALL 3 boards! :Q
I tested it at the shop where i bought it from without it being in the case and to my surprise it booted up! I could not believe that! So I bought it back home and tested it like I did in the shop and it restarted! :|
Any Help is greatly appricated!
jamesbond007
5,280
So when you brought the systems back home, were the motherboards in the case again? Perhaps there's a grounding issue?
Are the systems hooked up to a power-conditioner like a UPS? Or were they at the shop when they seemingly worked fine?
Have you performed a 'Reset to defaults' in the BIOS? Sometimes if you go through too quickly, you can make a stupid switch that can cause things to go awry.
Good luck dude! I'm subscribed waiting for a response. :)
