- May 10, 2011
- 2
- 0
- 0
Hi all! New on the forum and asking for some help!
I got back from my vacation and my PC stopped working. I had some problems before, but i thought it was just faulty RAM, which i RMA'd. After new RAM it got even worse. Could use some help! Thanks in advance.
The problems:
1. OS/PC freezes after a while of usage
2. No POST, No BEEP, Power ok, FAN ok, LEDs ok
3. POST ok, gets stuck on : Initializing USB Controllers ..
Workaround:
1. sometimes works - pulling out powercord for 5 mins - boots fine
but then after a while it freezes or restarts again and doesn't boot.
Tests i did: ( IF the pc worked, most of the time it did not )
1. tested memory with memtest 64+, no errors
2. swapped memory banks, no change
3. pulled out mem, got bios BEEPS, ok
4. pulled out GPU/VGA, got bios BEEPS, ok
5. reseated all cables, no change
6. reseated CPU, no change
7. tested with prime95, works ok for 10 mins, reboots, then no POST, etc.
8. checked temps, around 50-60 max, no prob
9. used no conductive underground and did a bare boot, no change, no beep
10. cleared CMOS ofcourse, used button and used battery-trick, no change
11. Used other PSU, no change
12. even changed other power outlet
PC setup:
CPU - i7 950 ( currently not OC'ed - in the past i oc'ed it to 4 ghz )
+ venomous-X cooler
MOB - MSI X58 Pro-E ( new )
RAM - GeiL 8gb DDR3-1600 ( RMA'd - new and working ok - memtest)
GPU - Powercolor HD5870
PSU - Corsair 750w
OS - Windows 7 Ultimate 64bit
The problems:
Workaround:
PC setup:
+ venomous-X cooler
PSU - Corsair 750w
