My 2yr old Athlon K7 700 Mhz on a PCChips 800LMR mobo died after a power supply incident. I'm a rookie to HW stuff, so could you guys pls. help me find the fault with my system. 250 Watt Power Supply sparked and died a day after installing a new Maxtor 80G drive. Replaced with a new Antec 300 W power supply. No use. Removed connections of all components one by one. Found that if I remove power to my old WD20G the CPU fans start up, but no beeps or video (CPU fans start just by plugging on mains I need not even push the power button on case??). Also the new HD, FDD and the CD all start simultaneously. Removed memory sticks and replaced with fresh ones. Could you guys guide me how to proceed.
Thanks in advance
Thanks in advance
