I have an AMD Athlon 1.1ghz processor
Shuttle AK31 motherboard with KT266A chipset
ATI Radeon 9500 Pro video card
Running Win 98.
In the BIOS, I have the temperature shutdown set to 75 degrees C.
And the computer shuts off.
I installed Motherboard Monitor and set the warning at 75. Sure enough. It sets off the alarm.
In the BIOS, I turned off the auto-shutoff (because I wanted to see what the temps were getting up to).
Found it reached 84 degrees! Decided this was bad. Opened the case. Temps went down.
Looked at all 5 fans (power supply, processor, mb fan, video card, case fan). All were running.
Checked voltages in MBM as well as processor fan speed. All look normal.
I do NOT overclock anything at all!
Bought a can of compressed air and blasted all the dirt and dust out of the case, the boards and the vents on the case door panels. Closed up the case. Temps were lower after that but still hitting the 75 degree mark.
Getting tired of having computer on the floor with the case open and a box fan blowing into it.
What could be my problem here?
I've heard theories. Maybe the seal between the processor and heatsink has broken?
Perhaps it's possible to replace heatsink and fan?
Some say that trying to do that will damage the processor and I'll have to replace it.
If I have to replace the processor, probably doesn't make sense to replace with the same thing. According to Shuttle, the newest BIOS for that board will support up to athlon xp 2000+. Never burned a BIOS before. Any suggestions? Don't want to have to replace the mobo too.
Solutions, thoughts, suggestions, ideas are all greatly appreciated.
Many thanks
Running Win 98.
Many thanks
