coffeejunkee
I did have a question about the guide, it said if you were running into stability problems, you should gradually raise the QPI/VTT voltages. It didn't say to raise the vcore at all.
Did you read all of it? The point is to do your oc in steps. First step is finding the required qpi/vtt voltage for a particular bclk. Next is finding the required vcore for a particular cpu multi.
But first get familiar with your bios, find out how to disable turbo boost and google any other settings you don't know. I'll say this now though, if you want to use the 22x multi you must disable c3/c6 states, else your cpu will use full turbo boost which will likely be unstable.
