- Feb 21, 2003
- 4
- 0
- 0
I am looking for a video card to connect my three monitors onto my desktop. All these three monitors are 21". One is Sopy G520P and the other two are E540/B, that is to say they can all support at least 1900x1600 resolution individually. Now I am considering to buy a Matrox Parhelia? 128MB card. However according to its specification,
while using 3 displays at a time (TripleHead), all 3 displays use the same displayresolution, color palette, and refresh rates, and the highest display resolution available is
1280 × 1024 (that is, 3840 × 1024 for all 3 displays). In this case the power of my monitors would be wasted. Can somebody give me some advice on this issue? I am not using this pc for gaming or video editing, therefore the 2D/3D performance is not important to me. My pc's configuration is
Dell Dimension 4550 P4 2.0GHz
1G PC2100 RAM
32MB ATI Rage 123 Ultra video card
I am also considering buying one Dualhead AGP card to work together with my ATI card. The question is whether this solution work or not. Shall each monito can work at least at 1600x1200 resolution? Can each monitor's resolution be set independently or not? Which kind of card should I buy?
My only experience with multiple monitors is connecting my G520P to a Dell inspiron 4100, thus my expereience on this is really limited. Any help or advice is grealy appreciated.
--strider
1G PC2100 RAM
--strider
